LS3 is in
Discussion in '1989-1995 Build-Up/Project Threads' started by aduarte, Jan 3, 2018.
  1. aduarte
    aduarte Member
    Avondale AZ
    1990 Toyota Base Model 2 wheel drive
    Greetings everyone,
    After many delays and setbacks, I finally got the LS3 with a 4L60e trans in my project. All that is left to do is the radiator. The motor is a 5.3 that came out of a 2006 Silverado and the trans was a spare trans that the owner of the Silverado had in his garage. The motor was rebuilt at the 120k mile mark and is equipped with a Trick Flo cam kit and heavy duty Mellings oil pump. I purchased a complete LS1 manifold from Hawk Motorsports and had it installed to complete the top end of the motor. The exhaust system is a set of Hooker block hugger headers with a dual system to a pair of Flowmaster mufflers. The motor and trans was installed in the truck with the help of a friend and his nephew in Phoenix. The trans was completely rebuilt with a 3000 stall converter and a shift kit was added and it shifts through a Lokar performance shifter mounted to the trans. The rear is currently the stock rear but I have a 8.8 with factory disc brakes that I pulled from a 1998 Explorer with 78k miles on the odometer that I will have rebuilt before I drop it in in the truck.
    As I stated earlier, the last thing I have is the radiator install. I bought a universal aluminum radiator from Jeg’s and I found that the filler cap was hitting my hood. I am working to have the filler cap relocated to clear the hood then my truck should be on the road. I will post some pictures of my build as soon as I figure out how to upload pictures on this site. I apologize for not being computer savvy enough to upload pictures. I rely heavily on my son to be my in-house computer tech.
    This forum has given me the motivation to do this project and I am always inspired by other truck owners on their builds. My plan with the truck is to be a daily driver and I would love to take it to a Mini truck gathering locally and on one of the Hot Rod Power Tour trips one day.
  2. jetas
    Glad youre getting it together. Hopefully you can get some pics loaded up soon.
  3. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Welcome
    Sounds like a great project
    All is left to do is slam that bitch to the ground on air ride!:cool:
  4. aduarte
    aduarte Member
    Avondale AZ
    Thanks, jetas. I will work on posting pics on my build.
    jetas likes this.
  5. aduarte
    aduarte Member
    Avondale AZ
    My plan is to install beefier T bars and sway bars up front and the 8.8 rear with a 4 parallel bar with coil overs to drop it. I don' t want to go too low.
    Blacklightnin55 likes this.
  6. Hands_On_Henry
    Hands_On_Henry Member
    Michigan
    1985 22R/4spd
    Sounds Awesome! Should be plenty of fun!
  7. aduarte
    aduarte Member
    Avondale AZ
    Yes, she was. On my first maiden voyage around the neighborhood, she was fun! I had a smile from ear to ear. The problem I am having now is that I bought an aluminum radiator from Jegs and my hood is hitting the filler cap. I found a local custom shop to relocate my cap and the truck will be on the road again.
    Hands_On_Henry likes this.
  8. Da_Roach
    Da_Roach Toyotaholic
    NOVA
    (1) 92 RN80 (1) 2002 RZN150
    I have full 1st on setup. 25mm front sway bar and 25mm torsion bars and the rear sway bar. Hit me up if interested . Look forward to the photos.
  9. aduarte
    aduarte Member
    Avondale AZ
    Da_Roach,
    I am interested in your set. Could you send photos and price for your parts to my email, [email protected]. Thanks.
  10. Blacklightnin55
    Blacklightnin55 Member
    Louisiana
    1990 Ext-cab
    Did you have any problem with the center drag-link clearing the oil pan. If so what did you do to solve the clearance problem.
  11. Justin Danger
    Justin Danger Toyotaholic
    Bay Area Peninsula
    I've heard the Holley pans have better clearance
  12. aduarte
    aduarte Member
    Avondale AZ
    I installed a Holley LS oil pan and it cleared the drag link. The front a arm crossmember was removed and I will have a tubing bent to clear the pan then I will weld it to the original location so I can remove it when I need to.
  13. aduarte
    aduarte Member
    Avondale AZ
    I installed a Holley LS oil pan. I have decent ground clearance with Holley pan.
  14. Blacklightnin55
    Louisiana
    1990 Ext-cab
    I should have went with a 8.8 ford rear end also. I got a 8.0 rear end from a pickup which had a 6 cyl. And also a LSD from a 92 supra. Will be sending it off for rebuild and have diff from supra drop into my rear end. Did not want to fool with the ford rear end due to it being sightly wider than the toyota.
  15. aduarte
    aduarte Member
    Avondale AZ
    I went with the 8.8 ford rear when I read in another swap forum where a Toyota pickup owner dropped the ford rear in his truck with no modifications. He stated that the leaf springs were about the same width as the ford, so the rear end dropped right in the truck with no issues. He relocated the hard lines for the brakes and he was done. The ford rear is slightly wider than the Toyota but if you order wheels with the required back spacing, it should tuck nicely inside the fenders.
    ent
    Erwin Merida likes this.
