lowering the front
Discussion in 'Suspension/Chassis' started by tylerzettner, Aug 5, 2013.
  1. tylerzettner
    tylerzettner Member
    Jerome, Idaho
    82 Hilux
    i have a 78 toyota pickup. i want to lower it about 3 inchs to 4 in the front. i have lowering block for the back they are 3 inchs. i dont want to cut the springs in the front. i was told the mighty max springs from belltech fit. then again the ride quality is the same i was told. i want to keep my handling but i want to lower the front end. if you have any websites or information. thanks
  2. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    Stock mighty Max springs give about a 2" drop. 2" drop springs give about 4". They ride very similar to stock. I've had drop coils for both and hardly notice a difference.
  3. 1980ToyotaModds
    1980ToyotaModds Newbie
    Hey tylerzettner I am lowering my Toyota this weekend im just going to loosen my tortion bars if you do it too much you may get quite a bit of camber if you want to go about an inch then you will be okay 2 1/2 inches more require a camber kit or special spindles or you will eat up tires pretty fast. Hope this helped.
  4. CurtisZ
    CurtisZ Addict
    Lake Stevens, WA
    1978 Pickup Longbed
    78 and earlier are coil spring up front (no torsions)
  5. standardbyker88
    lynnwood, wa
    Curtis! Haven't seen you around these parts in ages! I go right past your street on the way to work now. I saw the blue truck in your driveway one time I passed by.
    Anyways, you could get MM drop coils. And then you have the stock springs to either cut for a slightly different ride height, or you can swap to stock if need be.
    As for the camber statement, I had a 92 I dropped about 4" up front using all torsion adjustment for drop. That was about 7 years ago, but the camber was very mild. I never ate tires at an exceeded rate. My 78 on the other hand has about an 8" front drop. I have some major negative camber, but I also have a thick stack of shims between the upper control arm center shaft and the spring pocket. It's mounted on the inside of the pocket, so shims ADDS negative camber. Typical layouts, shims REMOVE negative camber.
    Hope this helps buddy. Post some pics when you're done.
  6. CurtisZ
    CurtisZ Addict
    Lake Stevens, WA
    1978 Pickup Longbed
    Hey! Yeah. The truck has been mostly a trash hauler, of late, and I haven't had the time to do much work on it, so I haven't been around the site much. I plan on changing that, though. I've been missing this place. We should hang out sometime soon. The truck isn't really cruise worthy with the leaky gas tank right now, but I'm looking for excuses to take it for short drives here and there...
