lowering question
Discussion in 'Suspension/Chassis' started by yotaman95, Oct 30, 2011.
  1. yotaman95
    yotaman95 Enthusiast
    Cottonwood Heights Utah
    1995 single cab
    i am new to this site and this question has probably been beaten but here is goes i drive a 95 yota single cab what do i need to buy to drop the front and rear end of my truck rather not do bags
  2. josealex1636
    josealex1636 Veteran
    Ontario,CA
    83 Toyota Pickup
    Wat up bro i am new to dis too but der is usually tension bars on da bottom that u can lower it or raise it nd u can use drop blocks for the rear....
  3. craigdbl
    craigdbl Guest
  4. GrantH
    GrantH Addict
    Hattiesburg, MS
    use the search button.
  5. josealex1636
    Ontario,CA
    83 Toyota Pickup
    Oh yeah der called torsion i forgot the name
  6. yotaman95
    1995 single cab
    oh word will the torsion way come loose and pop off though? and to do drop spindles do you have to do that fab on the break plate for it to fit?
  7. craigdbl
    craigdbl Guest
    I don't understand your 1st question.On my year I did have to fab the plate otherwise it would be in the way.There's posts for your year I'm sure.
  8. yotaman95
    1995 single cab
    do i have to get drop spindles if i do the torsion bars or will setting those be fine?
  9. craigdbl
    craigdbl Guest
    I tried just the torsion drop and the ride was too ruff for me. With the drop spindles you retain the factory ride. It's personal preferance I guess. I installed the spindles and cranked the torsion bars one inch and the ride is still good.
  10. yotaman95
    1995 single cab
    is it bad because you take you the shock pads?
