Lowering my 85 pickup, need HELP.
Discussion in 'Suspension/Chassis' started by MiniYota14, May 10, 2012.
  1. MiniYota14
    MiniYota14 Newbie
    85 xcab longbed
    I'm new to toyota minis, I've just recently seen some pretty sweet looking slammed yotas, so i figured i'd give my 85 a try. I've started with a 2" drop on the torsion bars. I was going to order drop blocks for the back, but i noticed my tires would hit my fenders if i went any lower. Is there a way i can go inside my fenders, if so, i would appreciate advice on how to do it. Anyone got any advice?
  2. jaybee
    jaybee Addict
    L.A.
    1987 yota truck
    what size is your rims and tires...wats the offset of the rims...if anything the best way is to get it rolled...
  3. '882wdyota
    '882wdyota Newbie
    yorktown va
    1988 2wd pickup
    got any pics?
  4. MiniYota14
    MiniYota14 Newbie
    85 xcab longbed
    I have 16" wheels, and 25" tires, the tires are a little big, but I bought them like a couple of months ago so the tread is still perfect and i really can't buy new tires yet. I have another set of 15" wheels that can be used, but the tires are shot and what exactly is "rolling" and could I do it myself??
  5. MiniYota14
    MiniYota14 Newbie
    85 xcab longbed
    no pictures yet, but i'll have some up soon.
  6. ResidentG33k
    ResidentG33k Enthusiast
    West Covina, CA
    88' 22R 2WD Single Cab
    What is the actual tire size? P195/75/R16? P205/75/R16? What jaybee said, you should roll your fenders so your tires will tuck when you hit dips and speedbumps
  7. Beefed Taco
    Beefed Taco Addict
    My guess is rolling the fender lip won't cure his problem. His wheels are most likely a low offset and will never tuck, no matter how much he rolls or trims his fender lips. This is a common problem. Deep wheels look great, but are always going to create a problem when trying to tuck.
    25" tire height is good, don't go above that, but I'm sure your problem is the wheels. I run a 89 axle in my 99 so my 9x18+36's will tuck with 275/35/18 and the 7" drop with trimmed fender lips, and I know there are different width pre 95 axles, so maybe try doing some R&D at a salvage yard and see if you can fine one narrower. I did my axle swap for $50 and a jug of oil thanks to craigslist .
