Load Boss Alternator
Discussion in 'Interior/Electronics' started by Mikerocosms, Aug 31, 2014.
  1. Mikerocosms
    Mikerocosms Veteran
    New Mexico
    1990 22R Pickup
    Just thought I'd ask before buying something. Are these alternators any good? This is the one I planned on getting:
    Load Boss
    I will be running a 4awg wire as recommended from battery to this alternator. Does anyone have any pro's or con's for this brand?
  2. Litneon
    Cocoa, FL
    94 xtra cab
    I did a small write up in my build thread of the HO alternator I built. Being in the factory case, I really doubt it'll put out 170 amps of current. I suppose it depends on how they measured it, as there are no industry standards.
    I was told that the most I could ever expect to get using the stock case is 130 amps, still a good jump over stock.
    The place I ordered all my parts from was out west, had everything in stock, and it cost me around $90 or $100. That's new windings, brushes, rectifiers, and voltage regulator.... everything. And rebuilding it is simple.
    My guess is, that it's all this ebay seller is doing, and then claiming 170 amps.
  3. Litneon
    Cocoa, FL
    94 xtra cab
  4. silverblazer50
    silverblazer50 Enthusiast
    Thomasville GA
    1994 reg cab
    I went with the marlin crawler gm mount kit, and a 120 amp factory alternator. The kits like $20, and you can get the alternator at a junk yard for cheap.
  5. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    That's how I do it. I run the stock alternator till it pukes then I build my own GM mount and slap on some cheap high amperage goodness.
  6. Mikerocosms
    Mikerocosms Veteran
    New Mexico
    1990 22R Pickup
    Interesting, I can build my own mounts but what year/model of GM alternator should I look for? Plus what would the wiring look like?
  7. White Trash
    Eastern WA
    There are hundreds of writeups on wiring but its stone simple. Pick most any gm alternator from about 73-88 and you'll get mini 68 amp.
  8. Mikerocosms
    Mikerocosms Veteran
    New Mexico
    1990 22R Pickup
    I decided to go with a Denso Part 210-0406 off of a Jaguar. It's 120amps and pretty much pnp. Supposedly fits in there snugly and with a little tweaking of the pulley mount it's adjustable.
    I'll probably end up getting the kit that Liteneon mentioned and work on that as a backup too.
