Well since I sold the supra it's been time to work on the truck so...... I finished the intake/battery location swap and swapped the battery to the passanger side corner of the bed used 1/0 guage welding wire and just ran the power wire to the starter then using the original battery/starter wire to the fuse block therefore no distribution block and a little cleaner look while still being cheaper. I also replaced a couple of grounds with the 1/0 guage wire. Next I cleaned up the fan wiring which more than likely I'll go back to the stock clutch fan since this electric fan has been nothing but a constant battle. I also decided I wanted some sound back so I bought/installed a jbl 10" sub in a truck box and a kenwood amp. Helped fill out the sound quite a bit. I don't need it to thump too hard since all I listen to is rock and similar. That's about it for now up next will be lowering it using block and torsion for now since I want to see how I like it and since I bought stereo stuff = no money for spindles and shock. I'll post some pics up sometime this weekend.
I just finished my relocation stuff not too long ago. Sounds like your ride will be close to what I have. Can't wait to see pics. Oh, and yes, it's all about having MONEY to get the job done!!
well took the carpet out today, vaccumed it, sprayed it with Super Clean, scrubbed with an interior brush, repeated, repeated, rinsed, and now it's drying looks waaaaaaaaaaaaaaaaaay better already though. I'll post some pics up tomorrow once the rest of the interior is done.
