LIMITED SLIP for my 82???
Discussion in 'Engine/Drivetrain' started by Joshualaterra, Nov 25, 2011.
  1. Joshualaterra
    Joshualaterra Newbie
    Ct
    82 dlx shortbed beauty
    Anyone have any suggestions about what i should do??? Limited slip? posi? The goal is good traction in the snow. I wanna do it now before it gets icy... THX
  2. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Call LC Engineering, they can tell you what is available & where to get! :cool:
  3. Joshualaterra
    Ct
    whereabouts are they located??
  4. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
  5. Litneon
    Cocoa, FL
    94 xtra cab
    That's a two edged sword. A locker or LSD will help with traction IF you have traction on either of the two wheels. If you lose traction on both wheels, you'd be better off having an open diff as you wouldn't slide sideways as easily as if you get both wheels spinning.
    If traction is what you want, you need a well siped tire to begin with, studs or chains might be needed, and then I'd consider an LSD.
  6. Raffaelli
    Raffaelli Toyotaholic
    Houston
    82 Longbed 2WD
    Just grab an LSD unit out of a celica supra. (82-86) IIRC.
    Not all of them have LSD/posi. But a build sticker or a quick spin of the driveshaft will tell you.
    Not easy to swap, as they require a backlash adjustment, but it can be done. Cheap and easy route if you do some junkyard hunting.
    Or you could drop 400+ bucks on an aftermarket locker...
  7. NashMan
    NashMan Toyotaholic
    Vancouver Island, Canada
    94 2wd
    doing the swap is very easy
    and the out come is pure fun
  8. Seventy6Celica
    Seventy6Celica Member
    San Gabriel Valley
    75 Hilux
    Do you have a 7.5" or 8" rear end? I just finished swapping a 3.91 gear set and LSD from an 88 supra into my 75. If you can rebuild the rear end then you can do this swap.
  9. tacobo670
    tacobo670 Addict
    Las Vegas
    94 Base
    ....is my next project. slowly but surely. and finding the right car is 80% of the problem.
  10. NashMan
    NashMan Toyotaholic
    94 2wd
    I have the 84 7.5 from supra in my truck right now and a supra lsd 8 inc from 86 to 92 with a spring upgrade kit it useless to me so it for sale because I forget to cheap what I had in my truck
    with the truck upgrade kit
    Weir Performance - MAXGRIP LSD Kits
    i will soon be buying the upgrade kit for my 7.5
