Been working on a new build with my 89 and been trying to get the lexus brakes to work on this build following the other threads posted in this forum. the problem I'm having is I have all the parts that everyone says works but the rotor offset is wrong, with the rotor bolted to the hub and hub mounted to the spindle there isn't enough room to fit the caliper mounting bracket in between the rotor and caliper mounting tabs on the spindle what gives? The threads Raffaelli has is mainly what I've been using anyone have anything better?
There seems to be various years mentioned but 95-96 lexus ls400 is what he list as using however they changed brake setups in 96 from what I can tell.
