LED's
Discussion in 'Interior/Electronics' started by Zombie Monarch, May 27, 2011.
  1. Zombie Monarch
    Zombie Monarch Veteran
    Springfield, MO
    1991 single cab dually hilux
    I'm looking to change my dashlights to LED's as soon as I get my exhaust all finished up. I'm going to be ordering leds from superbrightleds.com. Which of the white bulbs should I use to get that real crisp clear white look?
  2. joeynational
    joeynational Toyotaholic
    PHX,AZ
    91 2WD
    I would go with a surface mount led strip i put two in mine they are 5050 smd leds nice even light no hot spots its not plug n play tho...i might hav some pics in my build thread if not ill take some pics tonight
    Check out autolummination.com too
  3. Robert m
    Robert m Addict
    Apple Valley, Ca
    '94 single cab, 22re, 5spd
    wled-x5 in the natural white color. get a few extra too cause iv had a few go out and then i have to order like 2 at a time and pay for shipping again. also get a 74xhp for the climate controls light.
    WLED-x5 (194 type) Wedge Base bulbs Specifications
  4. jetas
    U can use a lil bit of acetone on the actual cluster to get rid of the color on the numbers n sh!t. Tha way the light comes thru better.
  5. Litneon
    Cocoa, FL
    94 xtra cab
    Pics?
    Or if you can find the other thread I saw a while ago, we could link it here...:)
  6. jetas
    Bout taking off the color on the gauges?
  7. Litneon
    Cocoa, FL
    94 xtra cab
  8. joeynational
    PHX,AZ
    91 2WD
    I did it its in my build thread the gauges have a green tint on them
  9. joeynational
    PHX,AZ
    91 2WD
    They shouldnt be going out that soon thats a sign of cheap leds they should outlast your truck i wouldnt buy from them again
  10. joeynational
    PHX,AZ
    91 2WD
    Here is mine on the hvac i put some Translucent colored film behind it to enrich the color you can see where it fell down in the blue its the lighter spot in the hvac i have a single 5050 #74 led plus i frosted the clear part behind the hvac
    On my gauges i have thestrips as i said, i had to add a additional resistor to bring the brightness down and i added the translucent red film on the tach, it was really faded looking without it the info on the film is in my build thread im happy with it now
