led tail lights
Discussion in 'Exterior/Body' started by merrick, May 30, 2014.
  1. merrick
    merrick Member
    alright guys using OEM wiring harness, I have some 3 wire (black, white, red) led strip lights. I cannot get the wiring right for the brake lights. I am almost certain I had this before but can't get it back. I understand the turn signal is a different story (relay) but trying to get the brake lights to work. The lights are coming on but not brighter when I brake. thanks!
  2. silverblazer50
    silverblazer50 Enthusiast
    Thomasville GA
    1994 reg cab
    Not sure, I'll check my book tonight and let you know what I find.
  3. LilRed93
    LilRed93 Addict
    Spanish Fork, UT
    1993 Pickup
    Brake and tail should be the same. Then blinkers and ground, right? You got a test light to help ya see what's going on?
