hey guys.. tried taking my leafs out the other day took the shock off u bolts off and to bolts that hold them too the shackels..but the bolts wouldnt come out any tips? also what do you guys thinkabout flipping leafs? cheers cal.
Dont recommend flipping them. Not good. Also you dont have to take the shocks off to get the leafs off. Have you already loosened the nuts on the 2 in the back and 1 on the front?
yeah took the nuts off the wond them back on a bit to hit the bolts through (not damaging the thread)
After you take the ubolts off and the shock drops down just try to wiggle them out. Give it alittle tap here and there and they should come right out.
If youre tryin to take the bolts off where the shackles are its not guna work. Theyre actually studs welded to some flat plate.
