I know some one on here may have the answer , I've been looking every where for lager front rotors for my 88 2wd truck,I know I will have to change the caliper,I want a 4-piston set up anyway. The only ones I found is a Wilwood kit,& the one from Canada ,very nice,very expensive!. 5-Lug,correct lug ( bolt pattern) & correct center hole size?? Someone must have done this!!
http://www.toyotaminis.com/forum/showthread.php?t=252 http://www.toyotaminis.com/forum/showthread.php?t=241 I think there may be a few more.... The brake setup should be the same for yours. I believe total cost was somewhere around $400-$500. Just a guess though, didn't read the whole blogs again.
