killswitch
Discussion in 'Interior/Electronics' started by lowest93, Mar 5, 2011.
  1. lowest93
    lowest93 Enthusiast
    sac town, cali
    93 toyota standard cab
    has anybody put a killswitch on their truck so it does'nt start so it wont get stolen, i just bought a alarm, and i just want to be extra safe.I have that, a wheel club and i want the killswitch. any ideas
  2. Kristian43
    Kristian43 Veteran
    Ventura
    89 Toyota Hilux Dlx
    Yeah the guy who did it said it had something to do with the automatic trans connector. It only works with a manual trans though. Ill figure it out and let you know
  3. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    wire a switch under the dash somewhere to an important relay. fuel pump or starter relay works good. in line of its signal, you run your own switch up to the dash and back. so if its off, that circuit won't operate. pretty simple. also works on the coil itself.
  4. jetas
    Wat ^^^ said
  5. synyster37
    synyster37 Member
    north carolina
    94 pickup
    yeah a killswitch is always a good idea when its done right. i believe my buddy joe (mxrider) did one on his mini
  6. kamesama980
    kamesama980 Addict
    Columbus, IN
    91 Base
    it can be done on either stick or auto. stick use the clutch start switch, auto use the PN switch. you can always use a couple relays or power transisters so it only starts in reverse (obviously stick only) with the park lamps (but not head lamps) on.
    Just remember that any security can only slow down the crook, not stop them. no matter what you do to it, they can find a way around it. plus if they make a habit of it, they know to look for switches and buttons.
    the PO of my truck was an idiot and wired it so the key did nothing but unlock the steering wheel. everything turned on via a switch on the left side of the column, and the starter was a 3/4" HD button on the right side. both in plain sight. he was a brilliant one...
  7. Bronga
    Bronga Member
    Anchorage, Alaska
    93 single cab base 22re
    my 92 2wd base and one of my friends subaru legacy both have something called an electrolock which a basically a key looking think that sits inside a housing and is bolted to the dash down by the hood release switch. if they key isnt in there then you can turn the key and electronics will turn on but the engine wont turn over.
    i use it everyone once in a while, like if i dont want my dad to drive my truck ill take it out and set it in the glove box and he has no idea why the truck wont start haha
