if any of u have huked up a kill switch on ur truck how have u dont it just got one 4 free off a friend so thot what the hell ill just put it on but have ni idea how any help will be great thx
Do you have a schematic of the trucks wiring? I would hook it up to ignition or fuel so you cut those off. What kinda switch is it? Just a regular flip switch?
I know removing the EFI fuse prevents the engine from starting but also will reset your ecu.. sigh.. next idea? lol
next and best idea. throw it away or in a box somewhere.. our trucks come stock with a kill switch, take out the key ...
maybe making sure doors locked yah but ignition no my 88 key will start my buddies 84 vise verse on top of that just about anykey will start a toyota ignition a thin enough screw drive will the trick...just about any late model toyota ignitions suck try some other key some time especially if key slides out the ignition while on pretty scary i say put kill switch just find wiring diagram and nice spot no one knows
well its a alarm but its for electric door locks but it says i can also us it as a remot kill switch so i just want to try and put it in cuz my truck has been stolen like 3 times found like in the next town over and everytime they dont tak nothing like motor just my system but would like for it not to get taken any more sick of haveing to go thru cops and all that crap
Hook it up to your clutch switch behind the pedal. That's what I did to a few of my trucks or hook up a kill switch to the fuel pump. Just a few ideas.
Keeping a low profile is a good technique and not pounding your sounds as well. Just install the whole alarm. Even if its for power locks, you can still wire it up and not use that function, or buy cheap "pushers" so it unlocks the doors. Just remember that if someone wants your truck bad enough, they will try ANYTHING to get it. No matter how many kill switches, alarms, and pit bulls you put in your truck.
Whatever you decide to do, make sure you cut into the wires at a discrete location. You dont want them to look under the dash and notice right away that theres a switch on the truck cause they can see where you wired it and will follow the wires to the switch.
