keeper
Discussion in 'Introduce Yourself' started by quail333, Nov 1, 2015.
  1. quail333
    quail333 Newbie
    joshua tree
    I have had my 85 long bed pickup since 1990, I like it. Now the Cali smog patrol is breathing down my neck. It is all stock with a new head and good compression. It is tuned with OEM parts and I think the TPS is adjusted right. The only thing I have not replaced is the catalytic converter. It failed smog twice, is there any reason I cannot get this right or is it good money after bad. I am ready to drive in to Longo Toyota and have them do a diagnostic, any thoughts?
  2. YOguyDA
    YOguyDA Addict
    Sacramento, CA
    1986 Regular Cab
    Need smog results....What part of the test is it failing?
  3. quail333
    quail333 Newbie
    joshua tree
    Thanks, I have settled down a bit after reading the relevant 22RE threads. My first test failed on Idle HC, the test came in at 154 PPM and the max was 150, so I went home and adjusted the Throttle Position Sensor, I think correctly, when I went back for a tailpipe retest the tech was showing an even higher HC, maybe 1000.
  4. YOguyDA
    YOguyDA Addict
    Sacramento, CA
    1986 Regular Cab
    How to Pass Smog
    A lot of good info here.
    Sounds like you need a cat....or your truck is idling rough (missing)?
  5. quail333
    quail333 Newbie
    joshua tree
    Thanks, I am studying the Smog thread. You get paranoid thinking the bludg wants to force you into one of those slinky import sedans. No it is running well and I saw improvement after adjusting TPS. Right now I think I will go ahead and get the new catalytic converter and put on a new Denso O2 sensor. Then do whatever I can glean from the Thread. After that if it still checks out weak I will drive 100 miles with red line in tank to big Toyota dealership and see if their hot tech guy can find anything on diagnostics before testing for smog.
  6. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    A BAD CAT WILL FAIL YOU!!:cool:
  7. hydroyota
    hydroyota Newbie
    las vegas
    1993 toyota pick up
    mine had 1500 hc i had a bent valve put all new valves in and and passed
