ka24 nissan swap
Discussion in 'Engine/Drivetrain' started by 1976yota, Mar 13, 2011.
  1. 1976yota
    1976yota Newbie
    Tucson Arizona
    1976 Toyota pickup
    i was thinking of dropping in a ka24de 4 cylinder into my 76 yota pickup and was wondering if anyone has experience with this swap i was on the website
    ka-t.com and was told 300-350 hp was achievable on a stock bottom end and 10 psi i know a lot of purists here are goin to get mad but a 20r doesn't get the power im looking for and any jz is to pricey can anyone give me any advice on this
  2. jackash002
    jackash002 Enthusiast
    NE FL
    1982 2wd p/u, 1983 toyota trailblazer, 1982 toyota truggy (next, just a cab/frame now)
    i thought about doing it since i had an extra KA motor, and wiring harness.. it would be easiest to find a beat up 240sx or hardbody and strip it of all it's parts. and you would need to get/make a custom driveshaft. motor/trans mounts. etc.
    there are a ton of aftermarket parts for the KA. but to do a decent turbo kit, even piecing together, your looking at least close to a grand ( varies quite a bit depending on parts used) plus the donor car and parts.
    anything is possible, just a matter of how much work your going to need to do/are able to do.
  3. oahu grown
    oahu grown Toyotaholic
    Hawaii
    92 Extra Cab
    Swap in a 2RZ. You can get power like that from low boost as well and its a toyota motor.
  4. Predracer
    Predracer Toyotaholic
    Conyers, GA
    Long bed 80 2rz turbo machine
    This, but it's a pain in the ass. and if you're going ka, might as well do a sr instead. Just saying haha
  5. TRfknD
    TRfknD Veteran
    The Woodlands, TX via (Guahan)
    96 Taco / 05 Tundra
  6. planemos
    planemos Toyotaholic
    British Columbia
    7Ms can be cheap. Kinda heavy though. The 2RZ is better. Just buy a Nissan truck to put a Nissan engine in it. Either way you will be rebuilding the engine at least once so you can turbo it.
  7. dOBER
    dOBER Member
    I got handed down a 98 Frontier xtra cab 2wd w a blown HG.
    not as easy to work on i have to say.
    I pulled the head, got it machined flat put on a new HG and cheaped out on tchain tensioner.
    it slipped and the the pistons got intimate w the valves
    16V headjob cost more than out 8V headjob!!!
    slapped everything back together with a NEW timing chain n tensioner setup
    didn't fire right.
    changed the cam alignement - fired but had a low end miss
    right now i pulled the valvecover and still trying to figure it out.
    I think my whole 22R rebuild was quicker than this nightmare I got myself into.
    Even thou my Toyota looks beat on the outside, it runs
    The Nissan is opposite, looks nice - (i keep getting offers to sell) but it don't work.
    As much as I'd like to swap out the engine, I like to keep it simple.
