JackStand
Discussion in 'Suspension/Chassis' started by jIM!, Mar 7, 2009.
  1. jIM!
    jIM! Member
    CA
    95' standardCab 2wd
    I have a 95' pickup
    and i was wondering
    where is the correct spot
    to lift your truck
    and to set the stands
    Pics would help if you can :D
    Gonna start changing my own oil and such
    and feel like a real Car Guy
  2. StupidSheet
    StupidSheet Addict
    Canada
    For the front I usually jack it up by the crossmember and I'll usually place the jackstands on the frame. Jacking up the back I put the jack on the rear diff and also put the jackstands on the rear diff. It all depends on what I'll be working on as for placing the stands. Hope that helps.
  3. toy_spd
    toy_spd Addict
    So.Cal -
    92 SR5 V6 Extra Cab
    yup thats what i do, i lift it so that theres enough room to move around under neath with out hitting the frame.
  4. smctoy
    smctoy Toyotaholic
    Florence, SC
    91 xcab...
    Ill take some pics for you tomorrow...I would have done it earlier, but I didnt see your question till now. I just jack the front up by the front crossmember like the others that have posted, but some pics will be helpful to everyone. :)
  5. Sound.Vision.Soul
    Sound.Vision.Soul Toyotaholic
    Ottawa, Canada
    93 Pick up I6 Turbo
    Yup thats it! Safest and easiest way to do it!
  6. jIM!
    jIM! Member
    CA
    95' standardCab 2wd
    Alright!
    Thanks
  7. smctoy
    smctoy Toyotaholic
    Florence, SC
    91 xcab...
    Here are some pics of how "I" jack up my truck & where I put my jackstands! Oh & consider this...my truck is non adjustable & is low as piss so I dont put the stands directly under the frame! :)
    my jack & stands...
    where I start to jack the truck up at...
    great place to put jack stands...right under the cab/frame mounts...
    plenty of clearance...
  8. smctoy
    smctoy Toyotaholic
    Florence, SC
    91 xcab...
    Ok...some more pics, but I put the stands under the front swaybar mounts for alittle more lift...
    final result...
    *Ok...here is another place you can put the jack if your able to get it under the truck lol...
  9. jIM!
    jIM! Member
    CA
    95' standardCab 2wd
    thanks for the pics
    Ima take a look under the truck tomorrow
