Is there a way??
Discussion in 'Suspension/Chassis' started by 92yota, Apr 18, 2010.
  1. 92yota
    92yota Member
    Hey guys recently I traded my 89 s10 for a 92 yota. It was bagged when I got it, But Ive been redoing everything because the way it was bagged was bad...Bags on lower bars but off the side of them so they twisted the **** outa the bushings and bolts. The axle also hit the bottom of the notch and it wasnt centered...I will post up pics when I get back from the store in a little bit, But I just wanted to ask this question quick first...Im getting ready to do the body drop prolly next week...In my driveway I have it laid out...I look under it and looks like frame lays all the way out...I touch the fame and ground and cant feel any space between them...The frame is not z'd...How is this possoble?? Is there another way besides "z"ing the frame to get it to lay out that the porevious owner might have done? Thanks guys, Hopefully someone has an answer for me.
  2. NotAvailable
    NotAvailable Addict
    to lay frame? all he had to do was make a new tranny crossmember and the truck will lay frame...
  3. 92yota
    92yota Member
    Yes, to lay frame...My frame lays out but the frame is not "z"d, so I was wondering how this is possible since everyone says you must "z" the frame to lay out. Sorry The rear is on jackstands right now cause im waiting till tomarrow till my buddys shop is open to get tubing to make new lower bars. So I cant really jack it up right now to look under it to see what has been done.
    P.S. pics comming soon.
  4. 92yota
    92yota Member
  5. NotAvailable
    NotAvailable Addict
    hey looks like just the tranny crossmember...idk about z ing the frame to lay frame never heard that one b4 because everyone who bags their toys they lay frame but they dnt Z the front they just make a new tranny member...idk..maybe im missing something..lmao
  6. 92yota
    92yota Member
    lol ok man well thanks for the info... Ill let you know when I get under it to see if it has a modded tranny crossmember. prolly does
  7. krazedprof
    krazedprof Addict
    iowa
    1991 reg cab & 1994 4runner
    i don't know how your laying full frame with out it being z'd unless they moved the control arms up my truck has the custom tranny cross member and still didn't lay in the front completely also it was laying on the engine cross member so maybe they built a custom one yours but mine will lay now (Z'd) well as soon as im done welding it up
  8. 92yota
    92yota Member
    Yeah see thats what im talkin bout lol...Idk how the hell it lays out, Its not z'd.
  9. burnzya
    burnzya Grand Toyotaholic
    arizona city, arizona
    bodied 73 hilux
    can you post up some pics of the front frame as well as the engine/suspension crossmember. a yota requires about a 1.25" z to lay full frame in addition to the modded tranny x-member.
  10. 92yota
    92yota Member
    Yeah ill get pics up after I make my rear lower link bars so i can actually lift it up and take pics
  11. NotAvailable
    NotAvailable Addict
    im lost because mine layed out all the way wen i bagged mine after i put the tranny member and i relocated the slave cylinder up 3inches because it was hitting?....hmmmm..maybe i got lucky :D
  12. 92yota
    92yota Member
    haha maybe we got freaks bro
  13. Metal worx inc
    Metal worx inc Newbie
    Hope Mills
    all u gotta do is make a tranny crossmember and that thing will lay out without being z'ed
  14. 92yota
    92yota Member
    Haha well then that's prolly what it has, cause it lays flat out. If that's all you have to do, then why does everyone swear that it has to be "z"d??
  15. krazedprof
    krazedprof Addict
    iowa
    but the engine cross member hits unless you do something custom with it cause like i said i have the tranny crossmember that tucks up it still hit the engine cross member so it wouldn't lay all the way in the front
  16. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    the reason alot of people z them is for larger tire wheel combos. they will bind the arms and get alot of camber. the crossmember will hand low, but alot of guys just drag til its flat. but i have heard this debate many times about yota frames.
  17. 92yota
    92yota Member
    Well ill let u guys know what has been done to it Friday night or Saturday when I get my new lower link mounts welded on so I can lift the truck up and see under it. Check my other thread in a lil bit for pics of the new brackets I finished up last night.
  18. burnzya
    bodied 73 hilux
    :brickknock: :brickknock: :brickknock:..... the frame will not lay full frame without a "z" or modded front suspension mounts. i think the confusion is coming from peoples ideas of what "laying out" is. some consider it the frame touching the ground in a couple spots, others consider it when the whole frame touches. it would require a huge amount of error at the toyota factory for some trucks to need it and some to not need it. here is a factory diagram for a toyota truck. it's an 85, but is pretty much identical all the way up till 95.
  19. NotAvailable
    NotAvailable Addict
    maybe it has to do with engine size? v6 and 22re and 22r...cuz i swear my motor crossmember never did hang below...all i had to do was remove that pipe thing that goes across and my whole frame layed except the radiaotor etc.
  20. jetas
    Post actual pics of these trucks laying out without a Z.
    To lay u dnt need a Z. To lay FLAT you do
