Irregular starting
Discussion in 'Engine/Drivetrain' started by Kev55, Nov 4, 2014.
  1. Kev55
    Kev55 Enthusiast
    florida
    1988 22re 180k+
    I turn the key and get a click. Doesn't turnover, just hear a click. I can try 10 times and the 11th time it will start right up. Sometimes it's on the 3rd try sometimes on the 1st and sometimes on the 20th
    At first I thought it was the starter but now I'm thinking some other electric component like a relay.
    Another thing that is weird. I can turn a bunch of times and only get the 'click'. but If it just cranks once and I stop before the truck starts. I can try again and it will crank perfectly again. like after it cranks that one time, then its good and I don't get the 'click'
    Any ideas? or definitely the starter?
  2. jetas
    Hows the battery. Check all the connections
  3. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    My 84 has had the same issue since I put it together several years ago. Sometimes it'll start on the first turn of the key, others it's the 20th. If I hit it with jumper cables or the boost setting on my battery charger it always starts on the first tickle of the key. I've installed heavy duty battery cables, brand new battery, new starter, replaced the excite wire to the solenoid etc. When I have time I'm going to swap in a relay to excite the solenoid and upgrade the grounds.
  4. SloPoke
    SloPoke Member
    corner of 33rd & go to hell
    93 standard cab dx
    With the miles on your truck and the symptoms you describe, I suspect your starter contacts are worn and need replacing. You can get them from the Stealership for a few bucks each.
    If you have something else to drive, yank the old starter, remove the contacts, and take them to the stealership to make sure you get the correct ones. They have several. Reinstall them in the starter and reinstall the starter. Viola.....good as new.
  5. 90DailyDriven
    90DailyDriven Veteran
    New Mexico
    90 standard cab 2wd short bed
    This. I sell those all day. Most common problem i see it that they wear unevenly since they are both different lengths at the end.
  6. Gr8KornHolio
    Gr8KornHolio Veteran
    Dallas, TX
    85 regular cab longbed 22R
  7. Kev55
    Kev55 Enthusiast
    florida
    This sounds suspect, I'll check the contacts out. thanks
  8. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    I posted the fix to this problem which is too low of voltage from the ignition trigger wire!:cool:
  9. Gr8KornHolio
    Dallas, TX
    Yea, I put a link 2 posts up that has your fix in it. Worked great.
  10. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    It is the answer, will never have that problem again!!:cool:
  11. SloPoke
    SloPoke Member
    93 standard cab dx
    Once the contacts wear down a bit, there's too much space for the magnetic field to work....so Truck Action's fix of considerably increasing the power to what generates that magnetic field will probably work even with the worn'est contacts. :waytogo:
  12. Kev55
    Kev55 Enthusiast
    florida
    I went ahead and tried this out and bought some generic relay that pretty much looks exactly like the one you had in the pictures. But no luck, same speratic symptoms.
    But while I was under there I did notice a sticker on the bottom of my starter that read "remanufactured" so it appears the previous owner swapped out the old OEM for this lower grade reman-part.
    So assuming I'll be buying a new starter today I guess
  13. White Trash
    Eastern WA
    I just fixed this issue on my 84 last weekend. I used 12 gauge audio power cable and a lawnmower starter solenoid. Starts every tickle of the key now.
  14. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    I'm very surprised that what I stated did not work. The use of the Ford solenoid fixes the problem. Just replacing the starter or contacts works for a while than the problem is back!! I know did all that!!
    After the mod I have not had the recurrence!!!!!!:cool:
  15. YOguyDA
    YOguyDA Addict
    Sacramento, CA
    1986 Regular Cab
    If the starter motor still turns over fine, you should get the contacts from toyota and open it up....Or open it up and check the contacts first? They're cheap and I'm curious :)
    That's probably all they replace in a rebuilt toyota starter anyway...
  16. Jetfixr
    Jetfixr Newbie
    The relay fix done correctly will work. You can also use your existing relay, you just have to cut the 12 volt source wire and route it to the battery. With a fuse of course. Did this myself. Starting problems for ten years before I found this fix posted somewhere. Don't know why Toyota use the 12volt source from the switch. Kind of defeats the purpose of using a relay. A wiring diagram will help.
    Jerry
  17. Jetfixr
    Jetfixr Newbie
