Into a shop
Discussion in 'Maintenance/Repair' started by TRUCK ACTION, Mar 12, 2022.
  1. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Taking Retirement Toy to the Yodaman's shop this Tuesday, he is the Toyota expect in Northern Cali .
    I have this idle problem for some time where if you hold the rpms at 2,000 after the engine is at running temp.it will drop & than go back repeatably. On a long road trip that will happen from 1,000 rpm .
    Hoping he can find the fix & at the same time I'll have him adust the valves,as I have not done that in a long time.
    jetas likes this.
  2. redman
    redman Enthusiast
    Southcentral PA.
    Let us know what he finds. Good luck.
    TRUCK ACTION likes this.
  3. Erwin Merida
    Erwin Merida Toyotaholic
    Long Beach, California
    LEXXXI - angry '93 ShortBed
    Like surging!? Sounds like vacuum leak.
  4. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    So I spent two days over in Santa Rosa, Larry found a bad 02 sensor & a bad TPS unit, changed both out & adjusted the valves.
    Problem seems to be fixed.
    The mechanic broke the drivers side inside door handle , of which they gave me a replacement part.
    I installed that & I'm changing the solenoid as it was working intermittently thumbnail.jpg
    Toyotashack and Erwin Merida like this.
  5. Erwin Merida
    That sounds legit!
  6. jetas
    Thats awesome, glad you got it fixed
  7. MikeH
    MikeH Newbie
    I replace my O2 sensor every 75,000 miles as preventative maintenance. It doesn't seem to need it when I do, but afterwards the performance improvement is noticeable. Gas mileage also goes up a bit as well. For $28 bucks for a Bosch unit it's worth it.
    Erwin Merida and TRUCK ACTION like this.
