Intermitten start issues
Discussion in 'Engine/Drivetrain' started by CrazyCody93, Aug 28, 2011.
  1. CrazyCody93
    CrazyCody93 Enthusiast
    Gresham OR
    84 Sr5 Xtra cab
    I have an 84 sr5 EFI, and typically if it sits for a long period of time, anything over 3 hours, when i roll it over, it will fire up, and then fall all the way back down and die. but if i bump it again, it will start and run perfectly. or it will idle really low, 500 rpm? until you give it a little throttle, and it starts to run just fine. but say i shut it off to go buy something inside the store, and come back, and it barely even has to roll over once and it fires and runs perfectly.
    any ideas on what my issue could be?
  2. jetas
    Fuel delivery issue?
  3. CrazyCody93
    Gresham OR
    84 Sr5 Xtra cab
    Its what i initially suspected, but i was suggested potentially an electrical issue,
  4. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    sounds like a leaky injector dropping your fuel in the rail so you fire it up and the rail has to build pressure and the truck dies, then second start up everything is ok.
  5. CrazyCody93
    Gresham OR
    84 Sr5 Xtra cab
    maybe the cold start injector?
    the only thing is it doesnt fire right away, it has to roll over 4 or 5 times, like i would expect it to do during a normal startup. and it will fire, and fall right back down and die.
  6. yodarolla
    yodarolla Newbie
    sounds like its losing prime somewhere
  7. CrazyCody93
    Gresham OR
    84 Sr5 Xtra cab
    well after some inspectoin under the hood, i did find a leaky fuel pressure regulator! Also explainse why my fuel mileage isnt quite right? but just for kicks we checked my fuel rail pressure, and i'm right at 30 psi. So its not quite a rough or low idle, after looking uip some specs, more of a miss at idle.
  8. dillinja666
    you have to start with the obvious. Replace the leaking fuel regulator and see if the problem continues
    a mis can be anything from an ignition problem to timing or even an air leak. I would start with the normal stuff like checking your cap/rotor and plugs for nasties and then go from there.
  9. OldSchool84DevilLux
    OldSchool84DevilLux Enthusiast
    Marysville, CA
    1984 Toyota Sr5 PU Xtra Cab(Hilux)
    I 2nd this:funnyup:
