Intake systems on 22RE
Discussion in 'Engine/Drivetrain' started by LilRed93, May 29, 2013.
  1. LilRed93
    LilRed93 Addict
    Spanish Fork, UT
    1993 Pickup
    I've always thought about doing a aftermarket intake but have no clue what to do? So I don't have to worry about Cali emissions. What's your input on this? Will it even make a difference?
  2. kamesama980
    kamesama980 Addict
    Columbus, IN
    91 Base
    changing the intake won't allow you to avoid emissions. If you are saying you don't have to worry about emissions testing and therefore want to change the intake, the most common thing is the intake/battery swap. Just use an elbow to turn the intake toward the passenger side with a cone where the battery was. Extend battery cables to the other side.
    Intake isn't the bottleneck so it won't help much. Just sounds like air sucking noise when you get on it.
  3. LilRed93
    LilRed93 Addict
    Spanish Fork, UT
    1993 Pickup
    I Do Have To Worry About Emissions Just Not Smog.
  4. Joe049
    Joe049 Member
    Las Cruces, NM
    94 Pickup
  5. LilRed93
    LilRed93 Addict
    Spanish Fork, UT
    1993 Pickup
    That's interesting. Looks like it worked well. Did you notice a difference to that from the stock box? Performance or MPG Gain? I'm sure its not much but anything helps.
  6. Joe049
    Joe049 Member
    Las Cruces, NM
    94 Pickup
    Yeah I noticed a HP gain, and as for MPG's not really. I can tell a little bit of a difference, but it's not much. The only thing with my setup is that the exhaust tube gets hot and starts sucking in hot air which reduces HP and possibly MPG's I think. But I'm planning on getting some header wrap for it soon!
  7. IronNam
    Moving the intake to the passenger side would reduce the intake tract length quite a ton and avoid it from having to soak up heat from the radiator.
    After that, provide an air duct to the intake because there's no hole for the intake on the passenger side. Or just drill one out lol.
  8. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    Do a true cold air intake,drawing air from outside the engine bay & use a K&N filter!!!
    That will make a difference, that & a big bore throttle body.
    Of coarse you should have a improved exhaust system also,headers,good flowing muffler & cat!
    The first & foremost in engine performance is getting your engine to flow more air,both in & out!! better!!!!!:cool:
  9. topcop182
    topcop182 Addict
    Colorado Springs Colorado
    1993 single cab 2wd
    This is good info. The best way to think of a motor is as an Air Pump. It sucks it in then spits it out...Turbos only compress the air more... Therefore the more air you can get into the motor, the more fun you will have....
    LAYNLOW likes this.
  10. NashMan
    NashMan Toyotaholic
    Vancouver Island, Canada
    94 2wd
    Ture cold air intake
    ps have a long intake pipe helps with low end power
  11. IronNam
    Intake runners are long enough as they are.
    most of your high revving is more HP based, so shorten the intake pipe to increase throttle response and reduce the length.
    I'm pretty sure the motor would be fine with helping itself shove air in the engine.
  12. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    I run a true cold air set up, pull air from passenger side ( short tube) outside inner fender,& from the from behind the front bumper! :cool:
  13. IronNam
    If I have time, I'll build a chamber to separate it all from the engine bay's heat.
  14. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    quick question for the EFI guys. Whats a stock throttle body size? I have a massive throttle body from a late model chevy. I am saving it for the next 22RE i hot rod out. Its like a 67 or 72mm.
  15. NashMan
    NashMan Toyotaholic
    94 2wd
    ^ Just a run a 7mgte from a 87 to 88 more then you will ever need
    and it bolts up have to mod it a tad but nothing to hard at all
    -Swap tps and tps turn plate from one to the other or swap clips and use the supra tps instead of the 22re one
    - use some jb weld and block so of the vac port off at the top
    - make throttle cable work
    if ya wana know more just look in my build thread
  16. standardbyker88
    lynnwood, wa
    I knew about the supra parts. Just wondering if their would be any use to the part I had. I have a carbed truck anyways lol. My buddy gave me his old throttle body when he put a bigger BBK one on.
