I'm stumped
Discussion in 'Engine/Drivetrain' started by yota4life, Sep 29, 2011.
  1. yota4life
    yota4life Grand Toyotaholic
    lodi ca
    1991 xcab 2wd 4cyl
    I replaced my blown transmission with another used one tht I knew worked well before. I replaced the rear seal today because it was leaking. All is good...not still leaking but I don't think it's the rear seal. Could it be the shifter gasket? And is it true you can only get it from Toyota?
  2. GrantH
    GrantH Addict
    Hattiesburg, MS
    rear valve cover gasket area.
  3. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    im confused did you replace the output seal on the trans or the rear main on the engine? Also is this an auto or manny tranny?
  4. kamesama980
    kamesama980 Addict
    Columbus, IN
    91 Base
    clean up under the truck, then you can see where it's leaking from. +1 for more info on what you're working on.
  5. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    Srry rear output seal on transmission. Manual trans
  6. Malessohomegrown
    Malessohomegrown Toyotaholic
    Malesso,Guam
    So after you changed the output seal and you're still leaking? Maybe you're not getting a good seal on the shaft. Try sanding it and maybe a little permatex.
  7. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    When I got home today I checked it and where I wiped I clean nothin there. But when I felt the bolts for the shifter they felt a little oily. So I'm thinking it's leaking from there. Everything else feels dry and I didn't replace tht gasket since I heard it's a dealership only gasket
  8. kamesama980
    kamesama980 Addict
    Columbus, IN
    91 Base
    RTV the shift housing gasket, I always have and it works fine on 25+ year old ones.
    How would you RTV the driveshaft :confused: It did occur to me as well that the shaft could have a groove in it causing the seal not to seal. If it did, it would be visible and simply not installing the seal as deep would fix it.
