Ignition setup
Discussion in 'Engine/Drivetrain' started by SD YOTA, Apr 4, 2010.
  1. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    Ok, so i poked around some of the old threads we have here and i got some basic info of what im looking for
    Im looking to amp up the Ignition system in the truck to make better use of the added air/fuel im getting. Ive seen everyone upgrade their ignition coil up to the MSD Blaster coil and also some better wires. With that, id like to know what else you guys are running in pair with this? what coil, what wires, what plugs, distributor, and timing set did you guys have? what brand parts did you guys use? any suggestions as to what to look for and what to stay away from........
    also something i found was that with the MSD coil, you need to use a "tach adaptor"? is this absolutely necessary? for that matter..... what does it do?
    thanks :waytogo:
  2. Guam_Guy
    Guam_Guy Enthusiast
    Copperas Cove, TX
    1994 Toy in the Project phase!
    The tach adapter is used when you are using the factory tach. I believe the voltage needs to be regulated somehow to get the right reading. I have never had to use one since I've always had an aftermarket tach. I would recommend the MSD 6AL w/ Blaster 3 Coil along with their wires. I haven't heard anything bad about Accel or Crane ignitions but I have always used MSD.
  3. suncomb1
    suncomb1 Enthusiast
    Pennsylvania
    1983 Toyota SR54x4 Mojave Edition-Black Package Shortbed Sport Truck
    I run a Crane CD ignition system with an MSD Tach adapter. I have tried MSD, Mallory, etc and found the Crane unit to be the most reliable. My motor pulls 285 HP with Nitrous on the Dyno and has a 6800 RPM rev. limit ignition setting (motor can go to 8500 RPM Max.) and I have never had any ignition system problems. I run 32 degrees total ignition advance with it all in at a little over 2000 RPM. I run NGK plugs and Taylor ignition wires. When I am not on the "Juice" I get about 19-20 MPG on the highway.
  4. KYNgsx
    KYNgsx Enthusiast
    Hawaii
    89 2wd
    ^^ My setup isn't quite as nuts as that, but the MSD 6AL and Blaster coil have been working good for me. I also run both my distributor and cam advanced, about 15 degrees at idle plus 5 degrees on the cam.
  5. Raffaelli
    Raffaelli Toyotaholic
    Houston
    82 Longbed 2WD
    Flame thrower coil. 15 degrees BTDC with no vaccum hoses connected. Good wires on Nippondenso plugs. .045 gap.
    Its simple, cheap and doesnt have a problem being driven by the factory ignitor.
  6. Evolmotorsports
    Evolmotorsports Veteran
    SCV cali
    1987 RN50 Hilux
    MSD blaster 2 coil, 6A that replaced factory ingnitor you dont need it, MSD super conductor 8.5 wires, E3 Plugs, Indexing washers. Only thing I can think I could use is a MSD distributer but I dont spin that high yet.:waytogo:
  7. Evolmotorsports
    SCV cali
    1987 RN50 Hilux
    And No you dont need an adapter, You just use I think its the pink to tie into your tach pluse wire.
  8. SD YOTA
    well..... im going back to a stock speedo temp and gas gauge cluster..... ill be running a auto meter tach since the stock tach cant keep up with the rpm speed changes...... :evil:
  9. TOY|STORY808
    TOY|STORY808 Enthusiast
    WAIPAHU TO LAS VEGAS
    1985 TOYOTA PICK UP
    u wont need a tach adapter on your truck.
    if i recall my friends 22re had to use one
    and used the diode setup. if not the truck would start but shut off right away.
    my setup
    6al, coil blaster 2, 8.5mm msd wires, 10 degrees advance on the dizzy, and .045 gap ngk iridiums
  10. Nook
    Nook Addict
    oregon
    I run the Mallory Unilite mechanical advance distributor, Mallory promaster coil, inline spike filter, 8mm wires on both mine, no complaints at all, did have a hyfire 6A box on for a short time but died after only about 3 months for no apparent reason, so took it off and never went back, never ran any better or any worse (until it died then didn't run at all :))and fuel mileage never changed with or without it.
  11. 22r
    22r Veteran
    Maui
    how do you hook up a msd 6a box to a msd coil for our trucks?? i cant seem to find any for the CARB22r's.
  12. suncomb1
    suncomb1 Enthusiast
    Pennsylvania
    Go to the MSD WEB site and look for the instructions for your model ignition control and download it.
  13. SD YOTA
    ok so im trying to decide what to do with my current distributor (stock) should i hard set the timing on my truck to around 20* btdc? or should i reconnect my vaccume advance and run 12*-15* btdc @ idle??
    not sure wich would be better at the moment? what do you guys think?
  14. B.Y.E.
    B.Y.E. Toyotaholic
    "671" Houston, Texas
    1982 2wd Hilux
    I would keep both mechanical and vacuum advance...
  15. standardbyker88
    lynnwood, wa
    78 lolux and an 89 ramcharger
    with my vacuum line unhooked, i have my motor set at about 16* btdc. That is with the stock compression on super. But it ran the same on normal gas, that gas just didn't like to hold up to the higher revs. I have a blaster 2 coil, and some 8/8.5 wires. Forgot which ones, but it was the largest set summit had available that were precut to length. I usually make my own lengths, but knew I wouldn't have much time to swap them coming up. The truck runs real good. I'd like to run a 6A box since I haven't ever tried one on a toyota.
  16. SD YOTA
    yea....... been wondering if it was worth the extra plumbing and i think imma go ahead and keep it..... i still need to go buy the msd coil and wires too....
  17. standardbyker88
    lynnwood, wa
    You'll be surprised at the difference when you get it revved out. It will seem like it wants to do it even more so.
  18. tyme_fo_play
    tyme_fo_play Addict
    94 BLOCK HAWAII
    MY PRIDE MY JOY MY TOY!
    my setup....
    -msd off road box
    -msd blaster 3 coil
    -8.5 msd wires
    -ngk iridium spark plugs (changed every oil change)
    -stock replacement rotor (changed every oil change)
    -stock replacement cap (changed every oil change)
    -and toystory808 advance my timing
    over all this **** does damage it has a better response, i can stomp the throttle with no lag in all gears. im thinking of adding the "msd 2step" (vtec?) but dont know how it really works i think you put the rpm chip for when you want the msd to kick in at it's prime then put in another chip so you don't over rev. msd never did me wrong.
  19. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    Right now i got all stocker stuff, running only at 8 degrees advance, with no vaccume hooked up. Runs good, but now that im 100% my motor isnt going to blow up or over heat im going to start messing with it. Doing my motor swap I was worried something would go wrong and leave me stranded, but since nothing has happened yet its time to mess with the truck. Have you guys been getting all your MSD stuff from summit or is there a cheaper place to get your components from?
  20. KYNgsx
    KYNgsx Enthusiast
    Hawaii
    89 2wd
    ^^ I got all my stuff from Summit. Not much of a selection locally anyway for me.
    The MSD unit doesn't "kick in"; it's always active. The 2-step is just a selectable rev limit normally used for launch control. This way you can have one rev limit for coming off the line (and launch full throttle) and a different rev limit for shifting.
