idling problems
Discussion in 'Engine/Drivetrain' started by joeyota653, Apr 24, 2011.
  1. joeyota653
    joeyota653 Enthusiast
    ok got a truck thatll start n run good..just wont idle at all.. gotta play with the gas to keep her going... any suggestions?
    i rebuilt the carb from a used one, changed spark plugs, exchanged cams, played with timing... did these and truck was running fine... then she started to sputter after a couple months... changed plugs n she got a little better.. kept the idle bt was sputtering. now she wont keep idling. any suggestions??
  2. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    sounds like your low end (idle circuit) is either too lean or possibly a clogged jet??
  3. joeyota653
    thanks for the reply SD... was thinking it was that... had a dirt bike that sat for a while... same prob.. later found it was the pilot jet:clapping:
