idle air control?
Discussion in 'Engine/Drivetrain' started by JYDGUSGUS, Jan 3, 2015.
  1. JYDGUSGUS
    JYDGUSGUS Newbie
    So I just bought my first Toyota and I've got a few issues I hope you guys can help me figure out. The really important one right now is the erratic idle.it idles a little high for a while when you first start it. But after about 2 minutes running it idles up to about 1800 rpm and back to idle. Im taking a guess and assuming its an idle air control valve but does anyone have any similar problems they have had like this? Its a 91 with a 22re 5 speed
  2. NashMan
    NashMan Toyotaholic
    Vancouver Island, Canada
    94 2wd
    tps out of adjustment or idle contact is worn out
  3. JYDGUSGUS
    JYDGUSGUS Newbie
    Whats the idle contact?
  4. Xs5875
    Xs5875 Addict
    Greenville, Ga
    1994 Standard cab 22re 5 spd
    On the tps. One of the terminals. Check and adjust your tps...Google it there's lots of walk throughs.
  5. JYDGUSGUS
    JYDGUSGUS Newbie
    Thanks guys I'll have to check that tomorrow
  6. Xs5875
    Xs5875 Addict
    Greenville, Ga
    But one less labor intensive check to eliminate a bad iac...take the intake elbow off the throttle body. See the large hole on the bottom corner? Cover it with a piece of duct tape. Read install the elbow and crank the engine...let it warm up just don't goose the throttle or you may suck the tape in. But since your issue is at idle you shouldn't need to worry about that. If the idle stays consistent. Then yes it's the iac under the throttle body.
    It's a thermo spring type setup. Works like a thermostat. Has coolant running to it which is supposed to shut the opening off when the engine is at temp. But they do go out. My last one did and I just made a block off and eliminated it lol.
  7. JYDGUSGUS
    JYDGUSGUS Newbie
    Well I looked over the truck and found it was low on water and gurgling it. Added water and let it run to try and get the air out and it seems to run fine now
  8. JYDGUSGUS
    JYDGUSGUS Newbie
    Well I spoke too soon. Checked maf and for vacuum leaks and coming up with nothing to fix this.
  9. tacobo670
    tacobo670 Addict
    Las Vegas
    94 Base
    pull the idle screw all the way out and check the O-ring for cracks. u may have over looked this part. i've seen this cause a surging idle. its worth a check.
  10. Xs5875
    Xs5875 Addict
    Greenville, Ga
    Did you try the fix I mentioned. I have a IAC off my 93 I'll sell you.
  11. TRUCK ACTION
    Vallejo,Ca.
    88 Extracab,2wd
    I had a problem witch was the same on my 88 /22re, found a broken wire @ the IAC!:cool:
