my truck hits bumpstops hard , is there any good idea someone knows on how to make it a little softer ? i have alredy cut them down .
Your best bet it to contact beef taco as he sells low profile high quailty bump stops for front and rear. I run them and love em
Sounds like it's time for a c-notch. I assume you're talking about the rear? My low pro bolt on's won't cure the problem but will give you max room while still running a bump stop. There's metal inside the stock ones that only allows you to cut them down just so far. Mine are about 5/8" from frame to bump. Better than slamming frame, but c-notching is the best answer.
