Well folks its getting to be that time of year when the temps drop at night. I was chasing water leaks all summer so I ran straight water to save money. A few nights back it hit like 35 outside and I think the ice wiggled the plug loose. Drcer side center below the header. It shot out driving, so I found it and put it back. Shot out again. So I got the expanding rubber kind for ease of install when hot. It shot out. So I got a new brass 40mm plug. I had all brass before in the 20/22R I built. I advise everybody checks how green the coolant is and check all your freeze plugs for dribbles, rust spots on steel and corrosion on brass.
I wasn't expecting the temps that low. It's running right now holding fluids. I'm glad I have reusable header gaskets.
Are your gaskets the carbon fiber graphite asbestos ones? A friend of mine had some custom made that are supposed to never blowout and you can reuse them.. Those suckers are like a 1/4" thick!
Lol nah, the head to header is the multi layer paper and graphite ones. But my header has a tendency to not stick to gaskets so I just reuse it. The flange gasket is the solid copper type sold in pairs for V8. I've had the best luck with the thick graphite head/header gaskets though.
Not additives, but the right chemical mixture to protect your Japanese metal, especially the aluminum heads and the coolant passages.
