i have a fuel cut off
Discussion in 'Engine/Drivetrain' started by l0wlux, Jul 18, 2009.
  1. l0wlux
    l0wlux Member
    when ever i hit high revs or like 80 mphs my truck starts to bog abd sputter like fuel cut off.............i just changed my fuel pump hoping it would be that but it still happens wondering what it could be?????????
  2. IronNam
    alt ground wire hanging around and slapping metal? that's what happened to me....
    check the usual stuff and take your time to look.
  3. l0wlux
    l0wlux Member
    witch wire would that be???? location?? color??? and so on
  4. IronNam
    eh.. from what I have... it goes from alternator to the Block. just one wire, black or white.
  5. l0wlux
    l0wlux Member
    fixed seems i put my float adjuster to high in my carb so not enough fuel
  6. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
    you try a fuel filter?
  7. IronNam
    Lol he had a carb.... not EFI.... silly me
  8. l0wlux
    l0wlux Member
    yeah but at sametime readjusted the float in the fuwl bowl.............
  9. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
    i would blame the filter more then the floats adjusting themselves.
    where is the fuel level in the sight glass?
  10. l0wlux
    l0wlux Member
    no i had readjusted m b4 then adjusted them again after changed both filters
  11. ShoNuff
    ShoNuff Toyotaholic
    seattle
    75 hilux, 80 4x4
    :rolleyes:
  12. l0wlux
    l0wlux Member
    i no more stock carb.............but its i say half inch high in the bowl
  13. TRDTUNERSR5
    TRDTUNERSR5 Newbie
    Riverside county
    1988 RN50
    ive been having the same problem..
    everyone is recomending to change the fuel filter.
    number two it may also be a spark issue.
    gonna change my spark plugs.
    because if i hit it full throttle is bogs down , and i have to slowly step on it to regain speed.
    in your guys opinions dou guys like asian carbs?
    all the off road guys like them ..
