...I can do better...
Discussion in '1989-1995 Build-Up/Project Threads' started by phatmitzu, Oct 29, 2008.
  1. phatmitzu
    phatmitzu Veteran
    SoCal 626
    93 Standard Cab 5spd
    Next time I will try to take a picture when the speed needle bottoms out.
    :D
  2. smctoy
    smctoy Toyotaholic
    Florence, SC
    91 xcab...
    now thats a cool pic! :D
  3. Sound.Vision.Soul
    Sound.Vision.Soul Toyotaholic
    Ottawa, Canada
    93 Pick up I6 Turbo
    What engine is in your truck... cause when i had the V6 in mine the rev limiter would kick in alittle over 180km/h. Never could bottom mine out :(
  4. Sound.Vision.Soul
    Ottawa, Canada
    93 Pick up I6 Turbo
    Lol oh and that pic got me thinking.....
    My first car. 1997 Suzuki Swift, had a 1.3L SOHC engine. redlined at 7200rpm. Spedo stopped at 150km an hour as you can see. I was going down a hill to pull that pic off.... lol
  5. IronNam
    wonder what road will let a 22re get up that quick
    on L i can hit 50 faster than being on D. as for top speed, idk
  6. tehsk
    tehsk Enthusiast
    Northridge, CA
    88 2.4L Carb
    Nice!
    My truck is stock and I can get to about 85~90 on a flat road. That's a sick picture, hopefully after I drop some performance parts in: exhaust, cold air filter, headers I can hit a higher top speed.
  7. phatmitzu
    phatmitzu Veteran
    SoCal 626
    5 speed 22re EFI with Cold Air(Box), Supra AFM, NGK Spark plugs, Spark plug wires, 4-2-1 Headers, Highflow cat, Full catback exhaust piping and Megaflow muffler.
    I can bottom out with both me(140lbs) and my friend(200+lbs) in the car.
    I should let him take an in-car video next time.... :D
  8. phatmitzu
    phatmitzu Veteran
    SoCal 626
    I did it on the freeway.
  9. nvrenufedge
    nvrenufedge Grand Toyotaholic
    Caldwell, ID
    bagged '93 std cab
    Had mine up to 110 mph once. In 4th gear! when I put it in 5th it started to slow down.
  10. 91HiLux
    91HiLux Enthusiast
    Paradise Valley, AZ
    1991 Toyota HiLux 4x4 RN101
    My old 2wd 94 Toyota Pickup went 117mph on the freeway.
  11. IronNam
    oh damn i gotta make use of the back roads then!
    anyways i got this sound from the valve cover area. sounds like two small blocks of wood clapping continuosly at a steady beat
  12. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    your lifters need adjusted.. u can hear it in your video.
  13. IronNam
    thanks for the tip. how do i do this? its totally different from the normal 22re clickity clack
  14. F1000X
    F1000X Member
    Yeah 117 is as far as I've gotten mine.
  15. IronNam
    ive got it to hit 90 and let off the gas til about 70, braked to about 45 an put trans into low to let auto control engine brake to about 20, then braked and fully stop at stop sign. no one was in sight but i touched the brake pedal slightly to have brake light on as i engine braked.
  16. F1000X
    F1000X Member
    I have a 5 speed. Its the only way to fly. Your larger cab will significantly increase your vehicles drag. It will be difficult to get it over 110 without some freeing of the exhaust system.
  17. IronNam
    my 4th gear (overdrive) was still going. after hearing 1st, 2nd, and 3rd make my motor scream, 4th was still pulling. is the hilux 4dr cab smoother than xtra cab? i know mine has this hump after the door on the roof. imma try to find a friend to fab me a 2.5" cat back and straight pipe it
  18. V8_TITAN
    Tampa Fl
    89 std cab
    with a magnaflow my truck only tops out at about 100mph... I also have a 4 speed though so that may make a difference in my top end.
  19. IronNam
    you got the mods and the manual, i just got the 4spd auto and extra cab haahahahhahahah.
    im thinking about rear end.
    my rear end code is F302
  20. IronNam
    anyways aired tires up to 35psi because first time i went 90 it was low than usual. i got to about 95mph on 30psi. i'll see whatever happens later on....
