hey guys do you noe how to make ur ride stiffer wen you crank the torsion bars down i dont like the bouncyness of my truck thanks for ur help
I used 69 Camaro gas-a-just shocks in the front to add stiffness. The stock torsions will give you a bit of adjustment.
chelu i removed the bump stops in the front and rear it helped wen i took it off but still bouncy i went on the freeway and hit a bump real hard and it jumped up on the road thank for ur help
Ok cool chelu. I guess try post #2 and #3 out... I personally tried pushing down on Raffy's 82 with the sway a ways and it's pretty stiff!
You can drop it 5 inches without even loosening your torsion bars. But spindles and LCA's cost money. Who knows how loose/soft your torsion bars are already. It took me a while to find that sweet spot when I just loosened mine. So maybe try raising em back up just a little
had a bouncy problem in my front end, just bought new shocks, problem solved. NEW SHOCKS will help. Also, could someone help me out with the torsion bars? i am yet to lower my front end, hows it done? pics would help. cheers.
