how to delete side views
Discussion in 'Exterior/Body' started by 390armstrong, Oct 18, 2015.
  1. 390armstrong
    390armstrong Member
    san diego CA
    90 xcab 3.0 vze
    Well figured id put this out since i couldnt find a place that sold mirror filler plates for our model...i also hate the space it leaves once done...so this is an easy way to delete the mirrors or set them up for motorcyle mirrors that can be unbolted...first of all i took the mirror off ....to do this take one screw off the pillar in the interior....aftet that you will see three screws holding the mirror to the door....once the whole mirror is off you will see a screw on the bottom of the mirror holding the triangle piece to the actual mirror.....remove that screw so only the triangle piece is left.. now use an angle grinder to cut the small piece off. After that you can grind the remaining mirror piece flat. All you have to do now is bondo the small rectangle left at the bottom and start sanding and painting...im posting from my phone so sorry if it comes out trashy....i will attach the pics in order
  2. Litneon
    Cocoa, FL
    94 xtra cab
    Why would you want to delete them? Just asking the obvious question.
  3. twizted1
    twizted1 Addict
    NORCAL
    '89 xcab 2wd
    I ask the same question...lol....starting to see a lot done like this at the car shows. and in mags.idk:shrug:
  4. 390armstrong
    390armstrong Member
    san diego CA
    90 xcab 3.0 vze
    Just for the smoothe look...i want to do motorcycle mirrrors but im still looking for the right ones...once i find them all i have to do is drill the hole and screw it on....
  5. TwinTurboTaco
    TwinTurboTaco Enthusiast
    Space
    92 2X
    Almost every 89-95 Pickup with vent windows and panel mounted mirrors has block off plates like that from the factory. They are plastic though, so no mounting motorcycle mirrors to them.
  6. Litneon
    Cocoa, FL
    94 xtra cab
    Well, That's a clever way to go about it for sure. The cast aluminum is stronger than the plastic cover plates.
    I went the other way though, as I didn't like the look of the stock mirrors. I picked up a set of mirrors from a 4runner that are larger and shaped better.
  7. Perkolator
    Perkolator Toyotaholic
    Placer County
    1975 Hilux
    instead of drilling any holes afterward, why not look into "peep mirrors"? They just clamp to your door. I saw some on a Toyota pickup online and I think I'll be converting over to them on my 75 since I don't have a passenger side mirror.
    Wile E. Toyote likes this.
  8. 390armstrong
    390armstrong Member
    san diego CA
    90 xcab 3.0 vze
    Finally finished the driver side....Do not go with $20 ebay mirrors i returned them cause the actuall mirror is cheap plastic. Make sure you get short arms for the mirror as well.
  9. 390armstrong
    390armstrong Member
    san diego CA
    90 xcab 3.0 vze
    Heres the pic
  10. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    Awesome now you have cool looking mirrors without that pesky ability to see what's behind you. :lol:
  11. Robert m
    Robert m Addict
    Apple Valley, Ca
    '94 single cab, 22re, 5spd
    :funnyup:
  12. twizted1
    twizted1 Addict
    NORCAL
    '89 xcab 2wd
    lmao!! i do like the look of the motorcycle mirrors. But you lose all visibility behind.
    Look sweet tho, so thats the trade off.
