How low can I go before C notching, etc.
Discussion in 'Suspension/Chassis' started by FrameBangin, Dec 22, 2015.
  1. FrameBangin
    FrameBangin Newbie
    Washington
    1993 Toyota Pickup DLX 2wd
    As the title says I'm just curious how low I can get my 1995 toyota pickup 2wd before having to c notch and other major fabrication, first post btw :waytogo:
  2. Perkolator
    Perkolator Toyotaholic
    Placer County
    1975 Hilux
    Tape measure. Everyone's truck height is different after 20years of use. Allow for a few inches of up travel, around 3"
    sojayota likes this.
  3. FrameBangin
    FrameBangin Newbie
    Washington
    So 4 inch blocks rear and djm lcas and drop spindles will be a bit too much?
  4. LAYNLOW
    LAYNLOW Veteran
    Amherst,VA
    93 Toyota Pickup 2wd
    In running 4" blocks now with NO leafs pulled out. And in doing fine. Im about to get 3" lowering leafs..im gonna have to notch then..ive heard/read anything more then a 6" drop in the rear youll have to notch.. but like Perkolater said..just have to measure
  5. FrameBangin
    FrameBangin Newbie
    Washington
    Okay thanks, thats good to know ^
  6. MrDinkleman
    MrDinkleman Addict
    SoCal
    1988 standard cab, long bed
    That's without bump stops or those low profile bump stops, right?
  7. White Trash
    White Trash Toyotaholic
    Eastern WA
    89 auto cross beater
    They are all different. My 84 x cab has 3" blocks and trimmed stock bumpstops and it hits the stops more often than not.
    My 89 has 4x4 leafs, shortened shackles and a 4" block with a 2" notch and I hit a lot. I really need to put bumpstops on it. :lol:
  8. LAYNLOW
    LAYNLOW Veteran
    Amherst,VA
    And yes without bumpstops...thank you mr dinkleman :)
  9. FrameBangin
    FrameBangin Newbie
    Washington
    What about the front end of the truck any limitations?
  10. jblaust
    jblaust Veteran
    Miami, FL
    1994 Pickup Standard Cab Base 22RE Manual
    Where did you get your 4" blocks? Did you have to drill them out to get the nipple that the block sits on from the leaf to fit? I was attempting to swap my 3 inch blocks for 4" blocks and the blocks I bought the guide hole is too small for the nipple on the leaf springs to fit.
  11. FrameBangin
    FrameBangin Newbie
    Washington
    Yeah ive heard about this issue to so im curious ^
  12. MrDinkleman
    MrDinkleman Addict
    SoCal
    Thanks! I was worried I was missing something when I finally have time to work on my truck. I only have about 3~4inches between my axle and bump stop with the stock setup.
  13. White Trash
    Eastern WA
    If you have the rubber isolators on the springs there is NO need to drill your blocks to fit the isolator in the block. Remove the isolator and put it under the block against the u bolt plate. Problem solved.
    jblaust likes this.
  14. Ghostwhite
    Ghostwhite Enthusiast
    Las Vegas
    86 reg/long 2wd
    The limit should be your ground clearance, I was static before and the first part to hit would be the crossmember on the ground. Now I'm bagged and I didn't have to change anything for clearance besides room for the bag.
    Static I used drop spindles rather than just cranked torsion bars, I had to add a little lift via the torsion bars after the 2.5 spindles and a ball-joint flip which kept my spring rate up and prevents bottoming as easy while riding low.
  15. FrameBangin
    FrameBangin Newbie
    Washington
    Okay thanks!
  16. LAYNLOW
    LAYNLOW Veteran
    Amherst,VA
    They were on the truck when i got it with a single leaf...:duh:. After i replaced the leaf "spring" with the factory leaf "springs"...i did notice the block wouldnt fit over the nipple so i did drill the hole to fit and it was good to go :waytogo:.....
    As for the front..i just have 2"drop spindles. Im gonna do a BJ flip when i replace my shocks
  17. jblaust
    jblaust Veteran
    Miami, FL
    I removed the isolator and the metal saddle that goes around the leaf springs. Apparently this feature only goes on the mid 90's pickup before they became the tacoma in 1995. All years previous to that did not have the isolator or metal saddle and the blocks sat right on top of the leaf spring pack (held in place by the u-bolts and rear end) and the standard bolt was 3/8 hole in the bottom of the lowering blocks. Once I removed the isiolator and metal saddle piece the bolt/ guide pin fit perfect in the 3/8 hole that comes standard in most lowering blocks. I did reuse the nipple part of the rubber isolator and I put it on the guide pin ontop of my blocks for a better fit into the rear end perch. That is the reason for the bigger rubber isolator in the first place.
    This is my old blocks that someone drilled out to make it work with the isolator. The new block is on the bottom with a standard 3/8 hole. I ended up replacing this with a custom set of 5" welded steel blocks.
