how do you remove cab completely from frame ?
Discussion in 'Suspension/Chassis' started by V8_TITAN, Nov 3, 2011.
  1. V8_TITAN
    V8_TITAN Toyotaholic
    Tampa Fl
    89 std cab
    like I said, whats the easiest way to remove a standard cab completely from the frame, there no motor or trans. truck is my 89...
  2. yota4life
    yota4life Grand Toyotaholic
    lodi ca
    1991 xcab 2wd 4cyl
    Take the bolts that go to the body mounts out. Remove all the things on he firewall. There are fuel lines an brake lines that are bolted to the underside of the cab. It took me an a buddy about 8 hours to completely strip my single cab. I'm talkin it went from running to a rolling frame in tht time. But should only take 5 hrs at most and 3 buddies to lift it off
  3. V8_TITAN
    Tampa Fl
    89 std cab
    Ok thanks. I'll look more into it tomorrow
  4. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    If it's stripped out makes it a little lighter. Good luck
  5. eurofreak2002
    eurofreak2002 Toyotaholic
    B-town 208
    One reason I have not bodied my truck yet, thats a TON of work just to get it off let alone do everything else.
  6. yota4life
    lodi ca
    1991 xcab 2wd 4cyl
    If you got a buddy with u it's not tht bad. It took us awhile because whoever bagged it welded the bed on and lost all the fatory bed bolts so they used regular bolts an it was a pain in the ass to get them out tht an it being mid 90s tht day so we were takin breaks
