How can i tell what size sway bar i have?
Discussion in 'Suspension/Chassis' started by SD YOTA, Mar 31, 2009.
  1. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    86 2wd toyota pickup........ there are two options for sway bar bushings on mine.... 18mm and 25mm.
    how can i tell what size i have? how do i measure it? :shrug:
  2. FOKAI
    FOKAI Veteran
    SD
    84 truck, 05 4Runner
    Measure the diameter of your sway bar with a tape measure(the ones tailors use if you have one).:shrug: .7 inches is 18mm .99 is 25mm. Measurements are approx.
  3. SD YOTA
    hmm........ for future refference for anyone else trying to find out what you have.... i found a "18" stamped on both of the sway bar bushings (frame end) facing outward.
    i also measured up the thickness and matched. this should help people determine what you have. :waytogo:
  4. IronNam
    25mm sway bar sounds soooo fun.... :D
    yours should fit on mine right?
  5. Sound.Vision.Soul
    Sound.Vision.Soul Toyotaholic
    Ottawa, Canada
    93 Pick up I6 Turbo
    If you cant find your stamp.. use a Vernier Caliper to measure the Dia. They can be bought for like 15$ if you dont have one. Very good tool to have!
  6. Evolmotorsports
    Evolmotorsports Veteran
    SCV cali
    1987 RN50 Hilux
    I believe the 25mm is only avialable on one tons and v6 models, due to weight of the v6 and stability for payload on the one tons.
  7. Evolmotorsports
    SCV cali
    1987 RN50 Hilux
    Oh yeah and second on the calipers, or micrometers will work too.
