Holley carb question........
Discussion in 'Engine/Drivetrain' started by SD YOTA, Mar 17, 2010.
  1. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    Can anyone tell me the difference between a 5200 and a 2300 model in the holley 500 carb??
  2. Nook
    Nook Addict
    oregon
    If I remember correctly the 5200 series were the ones that looked similar to the Weber downdrafts, and the 2300 series is the standard Holley 2bbl, looked like half of a 780cfm 4bbl
  3. SD YOTA
    so appearance is the only difference? the bolt pattern is the same im assuming?
  4. Nook
    Nook Addict
    oregon
    I,m sure there are apparent differences in how they function, the 5200 series is pretty much a clone of the Weber 32/36, probably a progressive throttle setup similar to the Weber with a smaller bolt pattern, where the 2300 series is both barrels at once, uses a larger bolt pattern, has external float adjustment, and uses most the same tuning components the larger 4bbl carbs use like shooter sizes, adjustable accelerator pump, and so on.
  5. B.Y.E.
    B.Y.E. Toyotaholic
    "671" Houston, Texas
    1982 2wd Hilux
    Mikuni's FTW! :ROFL:
  6. SD YOTA
    :lol:
    yea yea....... you probably think im nuts for doing so...... :evil:
