Hissing sound
Discussion in 'Engine/Drivetrain' started by Badlux, Jun 11, 2011.
  1. Badlux
    Badlux Enthusiast
    Kaneohe, Oahu
    87 xtra cab
    Im doing a complete rebuild and I just put my timing chain on and manually turned the engine over. I have the oil pan off and I can hear a hissing sound like its losing commpresion. Is this normal? I'm preety sure I did everything right???
  2. jetas
    Valve stuck open? Sparkplug not sitting proper? Or loss of compression.
    Could be some kind of friction also. Two pieces of metal moving against each other could cause a hissing sound.
  3. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    ya normal...happens when you turn the motor over by hand, air hissing out of the barely open valves.
    cool huh
  4. Badlux
    Badlux Enthusiast
    Kaneohe, Oahu
    87 xtra cab
    Thanks guys...I also found out it was normal. Its the air passing the ring end gaps.
