High level stop light - available?
Discussion in 'Exterior/Body' started by Ian Nexus, Jun 17, 2011.
  1. Ian Nexus
    Ian Nexus Member
    Torrance CA
    93 xcab 22RE 2WDAuto
    Has anyone seen a 3rd high level stoplight for the 92 xcab - I kind of feel a bit nervious in a smaller truck here - Jackson seems to be bad for being "rear ended" and not having high level stop like other trucks on mine :cry:
  2. patrickgraven
    patrickgraven Veteran
    Corona CA
    93 2wd pickup "home depot" / 2004 Toyota Sequoia 4x4
    I would assume you could just get one from a 94 or 95 truck. From what I have seen at the junkards it just bolts to the roof.
  3. jetas
    get a 10' pole, put it in the bed sticking straight up with a light at the end.
  4. eurofreak2002
    eurofreak2002 Toyotaholic
    B-town 208
    Yah my 94 Xcab had one it was factory. I thought someone was selling one a few months back or has one laying around so hopefully they see this post and help ya out
  5. IronNam
    some people don't like the 94-95 high stop light because it sticks up pretty high.
    if you want to go factory, there's nothing wrong with that.
    if you wanna get something more low profile, do it! make it unique. as long it's done right lol.
    I call my 94 stop light a shark tail lol
  6. jetas
    Fit a LED strip right above the back window.
  7. Litneon
    Cocoa, FL
    94 xtra cab
    Or in the top of the rear window. I actually removed my third cause it looks like a terd.
  8. joeynational
    joeynational Toyotaholic
    PHX,AZ
    91 2WD
    i flush mounted a ford explorer fluorescent third brake light, i re did it a while back with LEDs
    fluorescent
    LED retro'd
  9. Litneon
    Cocoa, FL
    94 xtra cab
    That looks nice man. Could've been factory.
  10. sherbasm
    sherbasm Newbie
    Fredvagas, VA
    94 xcab 4x4
    i've never been a fan of the high rise but i have a set of the led's from a chevy on my roof...took a little bit of work to cut the plastic casing of the strip but it fit perfect otherwise and was a simple plug and play more/less.
  11. 22R_All_Motor!
    22R_All_Motor! Addict
    Houstone
    84 pickup
    jetas beat me to it, but try mounting a light inside the cab right below the cab where it meets the glass... shouldn't be to hard to route a wire up there....
  12. ShortyzKustomz
    ShortyzKustomz Enthusiast
    Central Va.
    94 Single Cab
    This is going in the back window of my truck, since my 59 Caddy lights are a little smaller. This is a Cadillac Catera third brake light. All leds and just under 2 inches from being edge to edge of my back window :) $11 junkyard score, List price is Like $500 from Caddy. My stockers been shaved for a while. With my tint you wont see it till I hit the brakes
  13. Ian Nexus
    Ian Nexus Member
    Torrance CA
    Thanks for the information guys, I am keeping a lookout at local pull a part for a later model truck. If anyone has one of the "ugly" factory ones that they dont want anymore, I will pay postage to give it a new home on my truck. Im more worried about someone rear ending me than the trucks looks at the moment :)
  14. Ian Nexus
    Ian Nexus Member
    Torrance CA
    Found a stop/tail light that doesnt look crazy while getting some oil at wally world, $5.88 (as the truck was free Im not spending a fortune on it).
    Just spliced in a wire to the loom under the passengers seat - green/white, ran it under carpet - up under rear seat and tucked in rear window rubber.
    Two screws fix it to top rail of rear wind unit - doesnt look bad at all.
    Walmart.com: Blazer Surface Mount Stop/Tail/Turn Light: Automotive
  15. sherbasm
    sherbasm Newbie
    Fredvagas, VA
    94 xcab 4x4
    got a pic of this installed? i like the idea of the more/less hidden light until the brakes are hit
