hi guys new to this forum and need some help
Discussion in 'Exterior/Body' started by xtremecreator, May 21, 2014.
  1. xtremecreator
    xtremecreator Newbie
    corona
    I bougth a while back a 1990 Toyota 2wd I just recently swap the bumper off a 1992 4runner and trhis weekend im getting the fenders and grill. I want to know what would work better for looks on my truck and how can I lower it with out modifying or cutting any part of my truck and want to use bags so I can get it low and raised it when I drive around
    thank you in advance
  2. raylcc
    raylcc Addict
    Denver, CO
    So you do or you don't want to use bags? If you want to install bags, its most likely going to require at least a little modifying and cutting. If you just want a static drop, you can go with a block in the back and lower the front with the torshion bars. There's also the ball joint flip to get the front end lower still. That can all be done in your driveway with hand tools and a jack and jackstand. If your ok with modifying a little bit you can always lower the front end with spindles.
    I hope that helps.
  3. xtremecreator
    corona
    I would love to use bags but don't want to cut the back of the truck so I can use it as a truck. can it be done or should I just use spindle drop and block,
  4. yota4life
    yota4life Grand Toyotaholic
    lodi ca
    1991 xcab 2wd 4cyl
    Youll have to cut it up but you can always raise the bed floor and still use it
