Hi from the uk
Discussion in 'Introduce Yourself' started by mrgreg, Jun 21, 2011.
  1. mrgreg
    mrgreg Newbie
    wales uk (over the pond)
    91 2 door surf
    Hi all in the process off lowering a 2 door 4x4 surf and seems like this is the place to get the intelligent information to do the job right :shrug: at the moment the front seems to be running on the bump stops (not very nice on these roads over here) will lower ball joint spacers improve the ride :confused: Thanks Greg
  2. DionTDE
    DionTDE Addict
    Preston, ID
    93 single cab 2wd
    Welcome to TM. I do not know much about the surfs but I will give it a shot. Did you do a lower ball joint flip? is there any spacing in there? Also I would suggest removing the bump stops. I dont have any on my truck.
  3. R-Tan
    R-Tan Enthusiast
    Apple Valley, CA
    88 std cab
    Welcome! and i also have no bumpstops. so i woud try cutting or removing them.
  4. mrgreg
    mrgreg Newbie
    91 2 door surf
    Thanks for that I'll try the hack saw bit first on the bump stops, can you explian a b/j flip as it does'nt seem to be a common thing over here :confused: does it make a difference that mines a 4x4
  5. DionTDE
    DionTDE Addict
    Preston, ID
    93 single cab 2wd
    I have no idea with the 4x4 surf. If you could post some pictures of the lower arms and where the spindle attaches (basically your front setup) we could give you some pointers. I am very new to dropping vehicles myself but i did do my 2wd pickup. There is a few other people here that know a lot about it. I am sure they will chime in.
  6. mrgreg
    mrgreg Newbie
    91 2 door surf
    Sorted :) just trawled through the site and found SD yota's piece on doing the ball joint flip :funnyup: now understand :runaway: Brill site if you look hard enough you can find the answer Thanks for your help
  7. DionTDE
    DionTDE Addict
    Preston, ID
    93 single cab 2wd
    Actually that is what i followed when i did the ball joint flip on my truck. Well done thread. SD YOTA rocks!
