Help!
Discussion in 'Suspension/Chassis' started by ToySerrato, May 4, 2011.
  1. ToySerrato
    ToySerrato Enthusiast
    Perris, Ca
    84 Toyota longbed
    ok so i been wanting to drop my 84 toyota pickup for quite some time now..but i honestly dont know wat to do or wat to get! i need to talk to someone that knows their stuff..someone please help me get some ideas on wat to get to make it happen...
  2. jetas
    Pep boys has 3" lowering blocks. Get those for the rear. Its the cheapest and easiest. There are also drop leafs but tbat gets pricier
    For the front you can do 2" drop spindles, ball joint flip and cranked torsions. Or both. And if u can find some drop control arms u can do that too.
    Did you try searching thru the forums? The topic have been covered TONS of times
  3. Ruffles
    Ruffles Enthusiast
    Tent City, Washington
    80 SR5
    i agree with him ^^ try looking thru the forums to see which method you want to do and im almost certain there is a thread on them all!! Good luck and let us know whatcha figure out!!!
  4. eurofreak2002
    eurofreak2002 Toyotaholic
    B-town 208
    Yah search button up there on the top right next to the new posts button is your best friend. There are numerous ways some easy, some harder. Also take into consideration if your even gonna bag it or make it faster as this will aid in actual parts needed cause you dont want to buy stuff twice. But yah local auto parts store should be able to get drop block for yah so everything Jetas mentioned is legit and basic!
  5. SD YOTA
    SD YOTA Grand Toyotaholic
    2000 Toyota Tacoma 2wd
    what are your goals as far as the truck? what do you want it to look like and are you planning to do different wheels?
    if need be, i also do drop trucks here in San Diego (if you wanted it done).
    there are lots of options to drop. some methods cheaper than others, some easier than others, but just about every option out there can get you anywhere you wanna go with your truck. :waytogo:
  6. ToySerrato
    Perris, Ca
    84 Toyota longbed
    i do wanna get different wheels but i have no clue on wat to get honestly..
    i just bought 3" blocks so im lookin to install those soon
