Help?
Discussion in 'Maintenance/Repair' started by Noahj_95, Apr 7, 2011.
  1. Noahj_95
    Noahj_95 Member
    Hawaii
    94 xcab
    Can any one help me i have a 1994 toyota pickup v6 3vz 5speed and it bogs/looses power once and a while and some time not at all but it mostly happens wen i dribe my truck at night? I jus did a tune up and i changed my timming belt and pullys and all my belts idk wat is wromg with my truck but it only bogs and looses power sometimes and it dose it in all gears.Also my idle moves up and down?
  2. Sound.Vision.Soul
    Sound.Vision.Soul Toyotaholic
    Ottawa, Canada
    93 Pick up I6 Turbo
    Check the trap door in your mass air flow sensor. Sometimes they can get sticky.
  3. dillinja666
    dillinja666 Toyotaholic
    I gots no truck, for now
    maybe its scared of the dark? jk
    vacuume leaks, mis set cam timing, mis set ignition timing, cap/rotor/plugs corroded. if you did a timing belt you should know how to work though the basics and check everything first.
  4. Noahj_95
    Noahj_95 Member
    Hawaii
    94 xcab
    Do you guys think it could be the distributer or the o2 sensor?
  5. Dux_Trucks
    Dux_Trucks Enthusiast
    campbell CA
    1988 hi-lux std cab 2wd 5spd short bed
    it sound more like a loss of power.. check the alt./ cables/ batt.
    thats where I would start if the most of the problems are at night with the lights on I would guess
  6. Noahj_95
    Noahj_95 Member
    Hawaii
    94 xcab
    now its starting to happen in the day, but it comes and goes.
