I'm putting my drop spindles on, and flipping my B/J's and done with the pass. side. the DS are back on but I cannot get the stabilizer bar to line up with the ****ing holes! I got the rear bolt in after an hour, but not the front one WTF am I doing wrong?
Do you mean the strut bar? I had the same issue. I just used a BMFSD (Big Mo FO ScrewDriver) in one of the holes and pushed/pulled on it as I shoved the bolt in the other. It took some working to get it all aligned. If I remember correctly one hole was more in alignment than the other....I had to get the 1st bolt in the hole that was the most out of alignment...then the other was easy.
Well it LOOKS aligned, but the damn bolt won't go through! I did the screwdriver trick to get the first bolt in too
Lift the front of your truck up after you have both sides done. And then install your strut bar and drop her back down. fool
