Does anyone have a picture of their efi converted to carb need some help with a few plugs and hoses and also my alternator has an oval plug not a round plug and I put it on would i need another alternator harness
Only thing a carbed motor needs is a throttle cable gas feed and return line and optinal vacuum advance vacuum hose ...what extra hoses and plugs and lines are you referring to are they emissions related or Efi related .. If you don't have emissions regulations and or using a weber carb u can remove all the junk and hoses of the motor ..got any pics for reference
Ill get u some pics later...i have some efi related such as the coil plug going to a carb distributor and also alternator Rear plug not the same oval plug on the harness and i have an alternator with a circle connector
The alternator . I'd try to source a round plug from a junkyard harness and cut it leave plenty of wire then relate the colors to your harness wires .beats buying a alternator distributer shouldn't be to much of a pain just need to find wich wire does what on the 22re harness and relate them to the 22r dizzy . That might require a multimeter or some web fishing
