im trying to run some bullitt wheels and they bolt right on the front but i can barely turn without them hitting just about everything. i put a spacer on, i think 5/16th, and was able to turn full lock both ways. but the lug nuts barely have enough threads to grip on. how hard would it be to put longer studs on?
You will need to remove your hub... Same process as if you were swapping out rotors... Key trick, you can use rear studs up front. They are about 1/4 inch longer.
