so my truck fires up and i can run it and drive it just fine but i will not idle period... doesnt even try so wtf is going on anyone else have this problem????
Check for vacuum leaks on all the lines, as well as intake to head and carb to intake mounting surfaces. Or it might be the idle mixture screw or idle speed screw worked itself out of adjustment. Also make sure the wire is going to the idle speed cutoff solenoid still.
