well i am wanting to put a set of mustang wheel or some g35 wheels on it,now the mustang wheels have the same bolt pattern cuz i called the local tire shop but he said to check the hubs so not real sure if he's talking about front or rear or both
Ok I see. Some rims wont fit because of the circle thing around the dust cap on the center. also on the 88's in the rear there is a screw(philips) that screws into the brake drum. It will prevent some rims from sitting flush on the drum. But the good news is you can just unscrew it and put some permatex on it to stop **** from going in the hole and it will be fine. Best thing to do is a test fit.
Rear pilot ( center) hole is the same ,79-85 Mustang SVO rotors go right on .Not sure about the front,but would say yes! So the rims will also!
They should go on no problem maybe a small spacer. There's a yota in my town I just saw today with mustang rims
