Help! 22r idles very high.
Discussion in 'Engine/Drivetrain' started by Chucky, Oct 19, 2015.
  1. Chucky
    Chucky Enthusiast
    Southern Louisiana
    88 pickup reg cab,82 sr5 long bed,93 reg cab sr5
    Help me!!! My 22r idles very high. After swapping from a 22re in a 93 4wd... All 22r ignition. with weber 32/36.
    I tried correct timing. etc vacuim lines etc.
    Anything else I'm missing.
    Already have hot wire to choke.
  2. jetas
    Did you adjust the idle speed screw?
  3. Chucky
    Chucky Enthusiast
    Southern Louisiana
    No I haven't yet I'll look.. When I've done the swap did I needed to swap wiring harnesses too
  4. Chucky
    Chucky Enthusiast
    Southern Louisiana
  5. Chucky
    Chucky Enthusiast
    Southern Louisiana
    Ok here's more info. On it it starts and runs. At first crank still idles extremely high. I just realized that I were still running the electronic fuel pump in the gas tank and still running manual.
    would that be the cause it it idling real high??? (Too much fuel pressure)
  6. Chucky
    Chucky Enthusiast
    Southern Louisiana
    Found out both fuel pumps are running the one in fuel tank and the manual one still operating. Could that be the high idle cause I adjusted carb it came out a running truck.
