help??? 15" wheel with my suspension???
Discussion in 'Wheels/Tires' started by Tricky03, Mar 8, 2015.
  1. Tricky03
    Tricky03 Member
    Bend, OR
    '93 std cab, 2wd, short bed, 22re, 5spd
    I found some nice Rota Kyushu wheels on CL. They are 15x9's. The bolt pattern is correct but I don't know if 15's will fit the front suspension I'm putting on my truck. Will 15" rims clear a 2" dropped spindle and a 3 " lowered control arm up front and will the scrub line be ok with 15's in the back using 3" lowered leaf springs and 4" blocks? It's a '93 std cab short bed. Any help with this would be awesome!
  2. Gr8KornHolio
    Gr8KornHolio Veteran
    Dallas, TX
    85 regular cab longbed 22R
    First question would be what's the backspacing on those?
    I know I've measured my 85 and if I I go from a 14x6 to 15x7 and increase the backspacing by 1 inch, keeping the distance from the mounting plate to the fender the same, I'm pretty sure it'll hit the suspension at full turn. My stock wheels are tucked into my fender. I have spindles, LCAs and a BJ flip.
    So if you had a 14x6 and went to a 15x9 you'd want your backspacing to decrease by 3 inches to clear the suspension arms. This would probably stick the wheel/tire well outside the fender, or at least it would on my 85. Not sure the clearances on y'alls trucks.
  3. 1lowSr5
    1lowSr5 Addict
    In the garage
    90' xtra cab Sr5, 2003 taco
    Wouldn't be 3 inches but and inch and a half. 9" wide 0 offset would be 4.5" either way. 9" wide +35 should be just about perfect. The way I always reference offsets is 25mm is 1", + pushes out - pulls inward. Offsets can be confusing once you got it its easy. :waytogo:
  4. Tricky03
    Tricky03 Member
    Bend, OR
    Thanks for the backspacing info. It will help for sure. I keep seeing these trucks online with really wide 15's poking out and super low pro tires. Really reminds me of the good ol days back in highschool. Now I too can afford the nice rims and proper lowering suspension that I couldn't back in the day.I already have the suspension, 4wd fenders and stuff but want to get the proper wheel/tire info before I buy. I would like to achieve this look but haven't been able to chat with any of these guys to see what they have for suspension, wheels/tires, backspacing or rubbing/clearance issues. If you know of these guys or are one yourself, can we chat somehow so I can get the look I'm after? A see a lot of them are from Hawaii if that helps...
  5. 1lowSr5
    1lowSr5 Addict
    In the garage
    Not one of em but... Usually a 10" wide +56 (if I remember correctly) 1°-3° camber, 7-8" wide tire usually something like a 195/50 15 gets you the stretch some like more some less, 4:6 drop should put you in the game. Used to build these canibeat/ hellaflush cars day in and day out. You can also get crazy with fender flares, cut your stock fenders and flare them out. All kinds of stuff, depends on budget and where your final destination is. Skies the limit.
  6. Tricky03
    Tricky03 Member
    Bend, OR
    Thanks for the info. I'm gonna have to keep looking around for a wheel that comes in the right width and has the offset to clear everything. I'm going to keep looking for the owners of the trucks I find online to ask a few questions and get some answers. It's really hard to tell how it all works from just a picture. Who knows...?
  7. 1lowSr5
    1lowSr5 Addict
    In the garage
    Look in the 89-95 forums section there are a few Hawaii guys that should have some great info!! :waytogo:
