Heater controls
Discussion in 'Interior/Electronics' started by CrazyCody93, Oct 19, 2011.
  1. CrazyCody93
    CrazyCody93 Enthusiast
    Gresham OR
    84 Sr5 Xtra cab
    How do i get the heater controls out of my '84?
    My fan doesnt turn on the lowest setting, the only one i really want to use! and if i can get it out of the dash i think i can figure out whats wrong with it
  2. twizted1
    twizted1 Addict
    NORCAL
    '89 xcab 2wd
    does it only work on the hi setting?
    if its like the 89-94's there is a blower resistor under the dash, kinda up behind the glove box. 2 phillips screws hold it in and there is a plug that goes into it.
  3. CrazyCody93
    Gresham OR
    84 Sr5 Xtra cab
    it turns off, and properly changes on all the 4 usable settings, except the lowest one, it doesnt turn on at all. i will look to see if there is one like that in my truck
    Where is the blower resistor located? because i'm only seeing two wires off the motor, and it looks like they dive into the side of the truck
  4. veedubfreak86
    veedubfreak86 Enthusiast
    PNW
    89 toyota ex-cab 2wd
    the contacts on the electric motor are probly dirty you can either pull it apart and clean them or put in a new motor
  5. CrazyCody93
    Gresham OR
    84 Sr5 Xtra cab
    but the motor works perfectly fine
  6. CrazyCody93
    Gresham OR
    84 Sr5 Xtra cab
    So in what vacinity am I trying to look from here??
  7. CrazyCody93
    Gresham OR
    84 Sr5 Xtra cab
    anybody???
